HP Stream 13-c002dx Wireless Card Replacement
  1. HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: step 1, image 1 of 2 HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: step 1, image 2 of 2
    • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
    • Flip the laptop over so the bottom is facing up.
    • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
    • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
    • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
  2. HP Stream 13-c002dx Wireless Card  Replacement: step 2, image 1 of 3 HP Stream 13-c002dx Wireless Card  Replacement: step 2, image 2 of 3 HP Stream 13-c002dx Wireless Card  Replacement: step 2, image 3 of 3
    • Flip the laptop back over so it's right side up and open the screen.
    • Using a spudger, separate the keyboard surface from the bottom of the laptop.
    • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
    • Remove the keyboard assembly.
  3. HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: step 3, image 1 of 3 HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: step 3, image 2 of 3 HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: step 3, image 3 of 3
    • Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
    • Attached to the Wi-Fi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the Wi-Fi card.
    • Once the wire is removed, set it aside so it does not get damaged.
  4. HP Stream 13-c002dx Wireless Card  Replacement: step 4, image 1 of 3 HP Stream 13-c002dx Wireless Card  Replacement: step 4, image 2 of 3 HP Stream 13-c002dx Wireless Card  Replacement: step 4, image 3 of 3
    • Remove the screw holding the wireless card in place.
    • With the screw removed, gently pull back the Wi-Fi card and then lift it out of the laptop. You are now ready to insert the new wireless card.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,299
