HP Stream 13-c010nr USB Port Replacement
  1. HP Stream 13-c010nr USB Port Replacement, HP Stream 13-c010nr Disassembly: step 1, image 1 of 1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr USB Port Replacement: step 2, image 1 of 2 HP Stream 13-c010nr USB Port Replacement: step 2, image 2 of 2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr USB Port Replacement: step 3, image 1 of 2 HP Stream 13-c010nr USB Port Replacement: step 3, image 2 of 2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr USB Port Replacement: step 4, image 1 of 1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr USB Port Replacement, USB Port: step 5, image 1 of 2 HP Stream 13-c010nr USB Port Replacement, USB Port: step 5, image 2 of 2
    • Use a spudger to flip up the retaining flap on the USB port ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  6. HP Stream 13-c010nr USB Port Replacement: step 6, image 1 of 2 HP Stream 13-c010nr USB Port Replacement: step 6, image 2 of 2
    • Remove the three 3mm Phillips #0 screws from the USB port.
    • Pull out the USB port.
  7. HP Stream 13-c010nr USB Port Replacement: step 7, image 1 of 1
    • Remove the chip containing the two USB Ports.
Keegan Lapham
759 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Cagle Spring 2018 Member of USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 330
