HP Stream 7 Screen Replacement
  1. HP Stream 7  Screen Replacement, Battery: step 1, image 1 of 2 HP Stream 7  Screen Replacement, Battery: step 1, image 2 of 2
    • Make sure the tablet is powered off before beginning.
    • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
  2. HP Stream 7  Screen Replacement: step 2, image 1 of 2 HP Stream 7  Screen Replacement: step 2, image 2 of 2
    • Remove the eight 5 mm Phillips 000 screws.
    • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
  3. HP Stream 7  Screen Replacement: step 3, image 1 of 2 HP Stream 7  Screen Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
    • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
    • If you broke both tabs, scrape the tape and Battery off.
    • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
  4. HP Stream 7  Screen Replacement, Motherboard Replacement: step 4, image 1 of 1
    • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
    • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
    • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
    • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
  5. HP Stream 7  Screen Replacement: step 5, image 1 of 2 HP Stream 7  Screen Replacement: step 5, image 2 of 2
    • Remove the two 2 mm Phillips 000 screws from the motherboard.
  6. HP Stream 7  Screen Replacement: step 6, image 1 of 2 HP Stream 7  Screen Replacement: step 6, image 2 of 2
    • Once unscrewed, the motherboard separates from the rest of the device.
    • The speaker is soldered to the motherboard, but it comes off easily.
    • Forced separation may result in a damaged motherboard and/or personal injury.
  7. HP Stream 7  Screen Replacement, Screen Replacement: step 7, image 1 of 1
    • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
  8. HP Stream 7  Screen Replacement: step 8, image 1 of 1
    • Using your spudger, pry the display panel off the front.
  9. HP Stream 7  Screen Replacement: step 9, image 1 of 1
    • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
6 other people completed this guide.
Justin Schnorf
252 Reputation
2 Guides authored
Cal Poly, Team 18-5, Forte Fall 2016 Member of Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Members
6 Guides authored
6 Guide Comments
where can i buy new screen????
eibrims - Reply
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - Reply
Where can i buy a new screen for the stream 7 please??
migueajr - Reply
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - Reply
We're I can buy the replacement screen?
Raymond Borrero - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 26
All Time: 4,475
