HP Stream 7 Battery Replacement
  1. HP Stream 7 Battery Replacement, Battery: step 1, image 1 of 2 HP Stream 7 Battery Replacement, Battery: step 1, image 2 of 2
    • Make sure the tablet is powered off before beginning.
    • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
  2. HP Stream 7 Battery Replacement: step 2, image 1 of 2 HP Stream 7 Battery Replacement: step 2, image 2 of 2
    • Remove the eight 5 mm Phillips 000 screws.
    • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
  3. HP Stream 7 Battery Replacement: step 3, image 1 of 2 HP Stream 7 Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
    • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
    • If you broke both tabs, scrape the tape and Battery off.
    • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
3 other people completed this guide.
Nelson Thai
233 Reputation
1 Guide authored
Cal Poly, Team 18-5, Forte Fall 2016 Member of Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 24
All Time: 7,465
