HP Touchsmart IQ506 RAM (Memory) Replacement
  1. HP Touchsmart IQ506 RAM (Memory) Replacement, Unplug the system: step 1, image 1 of 2 HP Touchsmart IQ506 RAM (Memory) Replacement, Unplug the system: step 1, image 2 of 2
    • Unplug the power brick from the system.
  2. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: step 2, image 1 of 3 HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: step 2, image 2 of 3 HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: step 2, image 3 of 3
    • Unscrew the RAM door using a Phillips #1 screwdriver. Snap the RAM door off from the bottom and slide it off.
  3. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM: step 3, image 1 of 2 HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM: step 3, image 2 of 2
    • With the RAM exposed, remove the RAM from the slots on the system by pushing the tabs back. Once you do this the RAM will pop up and you can remove it.
    • Install the new RAM. Make sure you line the tab up on the memory with the slot in the system. It should only go in one way.
Nick
93,531 Reputation
59 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,699 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 788
