You're viewing a previously published version of this guide.  View latest version
Older Newer
HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement
Eeshan Mishra
Eeshan Mishra and 4 other contributors
Last updated on October 31, 2022
1 hour
Moderate
Featured Student Guide
Introduction
Go to step 1
This guide goes over how to replace the controller's main circuit board.
If your TPC-Q044 circuit board starts failing when using your controller, you may want to think about replacing the component. The failure may be a result of bad soldering or missed connections. The replacement of the circuit board is not too complex. A couple of screwdrivers and a spudger will be sufficient to complete this task. There are no warnings or potential hazards when replacing the board.
Tools
Show more…
  1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: step 1, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: step 1, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: step 1, image 3 of 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: step 2, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: step 2, image 2 of 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 3, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 3, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 3, image 3 of 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 4, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 4, image 2 of 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: step 5, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 6, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 6, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 6, image 3 of 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
  7. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: step 7, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: step 7, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: step 7, image 3 of 3
    • Remove the two 6mm screws at the base of the ring using a Phillips #0 screwdriver.
    • Pull towards the base of the controller to release the black wire from the connector on the circuit board.
    • Pull the ring apart from the rest of the controller.
  8. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 8, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 8, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 8, image 3 of 3
    • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
    • Remove the V-clip from the device.
  9. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 9, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 9, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 9, image 3 of 3
    • With the V-clip off of the controller, use a Phillips #00 screwdriver to remove the remaining 4mm screw.
    • Remove the circuit board.
Eeshan Mishra
424 Reputation
4 Guides authored
Cal Poly, Team S1-G2, Maness Spring 2019 Member of Cal Poly, Team S1-G2, Maness Spring 2019
CPSU-MANESS-S19S1G2
4 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 17
All Time: 2,036
