HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: step 1, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: step 1, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: step 1, image 3 of 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: step 2, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: step 2, image 2 of 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 3, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 3, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 3, image 3 of 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 4, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: step 4, image 2 of 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: step 5, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: step 5, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: step 5, image 3 of 3
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
4 other people completed this guide.
Clement Cheung
643 Reputation
5 Guides authored
Cal Poly, Team S18-G5, White Winter 2019 Member of Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,655
