HP Z2 Mini G3 Access Panel Replacement
  1. HP Z2 Mini G3 Access Panel Replacement, Access Panel: step 1, image 1 of 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Access Panel Replacement: step 2, image 1 of 2 HP Z2 Mini G3 Access Panel Replacement: step 2, image 2 of 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Access Panel Replacement: step 3, image 1 of 2 HP Z2 Mini G3 Access Panel Replacement: step 3, image 2 of 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 31
All Time: 1,056
