Introduction
The motherboard connects and powers HP Z2 Mini G3 (Model No. 1LE81UP#ABA) hardware components. Communications between the CPU processor and other hardware components is possible because of the motherboard acting as a printed circuit. If you need to replace your motherboard, follow this guide.
Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device.
Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
Remove the 9mm Torx screw with a T15 Torx screwdriver to release the SSD assembly.
Lift the assembly upwards to remove it.
Remove the thermal sensor cable from the motherboard.
Grab and lift the cable from the chassis to finish removing the thermal sensor.
2 other people completed this guide.
