HP ZBook 15 4G Network Module Replacement
  1. HP ZBook 15 4G Network Module Replacement, Battery: step 1, image 1 of 2 HP ZBook 15 4G Network Module Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 4G Network Module Replacement, Back Cover: step 2, image 1 of 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 4G Network Module Replacement, 4G Network Module: step 3, image 1 of 1
    • Remove the two connectors by lifting gently with a metal spudger.
  4. HP ZBook 15 4G Network Module Replacement: step 4, image 1 of 2 HP ZBook 15 4G Network Module Replacement: step 4, image 2 of 2
    • Remove the 3mm screw with a Phillips #0 screwdriver.
    • Remove the 4G Module by lifting up and out.
3 other people completed this guide.
Grant Terris
2,882 Reputation
12 Guides authored
Cal Poly, Team 8-43, Amido Winter 2015 Member of Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Members
15 Guides authored
1 Guide Comment
this instructions were very useful
PRINCE - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 31
All Time: 5,547
