HP dv5-1125nr Battery Replacement
  1. HP dv5-1125nr Battery Replacement, Battery: step 1, image 1 of 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Battery Replacement: step 2, image 1 of 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 other people completed this guide.
Nick Loey
1,676 Reputation
8 Guides authored
Cal Poly, Team 9-15, Regan Spring 2014 Member of Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Members
10 Guides authored
2 Comments
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - Reply
what is your return policy?
glopam2013 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,195
