HP iPAQ H2200 Joypad Replacement
  1. HP iPAQ H2200 Joypad Replacement, Battery: step 1, image 1 of 1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 Joypad Replacement: step 2, image 1 of 2 HP iPAQ H2200 Joypad Replacement: step 2, image 2 of 2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 Joypad Replacement, Main Board: step 3, image 1 of 1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 Joypad Replacement: step 4, image 1 of 1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 Joypad Replacement: step 5, image 1 of 1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 Joypad Replacement: step 6, image 1 of 3 HP iPAQ H2200 Joypad Replacement: step 6, image 2 of 3 HP iPAQ H2200 Joypad Replacement: step 6, image 3 of 3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 Joypad Replacement: step 7, image 1 of 2 HP iPAQ H2200 Joypad Replacement: step 7, image 2 of 2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 Joypad Replacement: step 8, image 1 of 1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 Joypad Replacement: step 9, image 1 of 1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 Joypad Replacement: step 10, image 1 of 1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 Joypad Replacement: step 11, image 1 of 1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  12. HP iPAQ H2200 Joypad Replacement, Joypad: step 12, image 1 of 1
    • Press on the four joypad tabs on the back, and push it through and out the front.
  13. HP iPAQ H2200 Joypad Replacement: step 13, image 1 of 1
    • Push the new joypad through the hole; the tabs will lock it into place.
Tyler Andrews
209 Reputation
5 Guides authored
Cal Poly, Team 4-12, Forte Winter 2010 Member of Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,059
