HP pavilion 15-cs3073cl Disassembly
  1. HP pavilion 15-cs3073cl Disassembly, Remove front screws: step 1, image 1 of 1
    • Begin by removing the 3 screws on the bottom front of the laptop. A Phillips #00 works well here.
  2. HP pavilion 15-cs3073cl Disassembly, Remove hidden screws: step 2, image 1 of 2 HP pavilion 15-cs3073cl Disassembly, Remove hidden screws: step 2, image 2 of 2
    • There are 3 screws hidden under the rubber pads. Using a pry tool or something thin like a credit card to remove the glued on rubber pads you will find one screw on the left back and 2 under the right pad. Phillips #0 works well to remove these larger screws.
  3. HP pavilion 15-cs3073cl Disassembly, Pry the upper and lower body: step 3, image 1 of 1
    • With a thin pry bar or credit card push in between the upper and lower parts of the body and you'll hear a clicking sound as the tabs release the 2 pieces. Go all around the laptop until the bottom cover is completely off.
  4. HP pavilion 15-cs3073cl Disassembly, HDD removal: step 4, image 1 of 1
    • If you're upgrading the HDD remove the 2 screws on the exposed side and lift from that side. The other side is being held by 2 rubber nipples on a thin rubber strip that will bend as you pull the drive.
4 other people completed this guide.
Josue Nolasco
226 Reputation
1 Guide authored
Green Shield Technology Member of Green Shield Technology
Business
2 Members
1 Guide authored
2 Comments
Good day,
Can we have the part number?
Cate Ledezma - Reply
Hello, I’m not sure what part number you’re looking for. These instructions are for the disassembly of the laptop as stated in the title. Once disassembled, you can replace any parts you need.
Josue Nolasco - Reply
Past 24 Hours: 4
Past 7 Days: 38
Past 30 Days: 76
All Time: 4,918
