HP w2216h Power Button Replacement
  1. HP w2216h Power Button Replacement, Power Button: step 1, image 1 of 3 HP w2216h Power Button Replacement, Power Button: step 1, image 2 of 3 HP w2216h Power Button Replacement, Power Button: step 1, image 3 of 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  2. HP w2216h Power Button Replacement: step 2, image 1 of 1
    • Do not pull the screen away to hard, this could snap the power cable.
    • Remove the power button from the top of the plastic frame.
  3. HP w2216h Power Button Replacement: step 3, image 1 of 1
    • Remove the power cable by carefully sliding it out of it's plug.
    • Check if there is any tear or fray in the cable.
2 other people completed this guide.
Sadeq Taha
219 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 866
