HP-Compaq G71-329WM LCD Replacement
  1. HP-Compaq G71-329WM LCD Replacement, LCD: step 1, image 1 of 1
    • Remove the 2 Screw covers from the lower sides of the Bezel
  2. HP-Compaq G71-329WM LCD Replacement: step 2, image 1 of 1
    • Remove the 2 Screws using a PH#1
  3. HP-Compaq G71-329WM LCD Replacement: step 3, image 1 of 1
    • Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
  4. HP-Compaq G71-329WM LCD Replacement: step 4, image 1 of 1
    • Remove the 2 screws from the top of the frame, One on each side.
  5. HP-Compaq G71-329WM LCD Replacement: step 5, image 1 of 1
    • Remove the 4 screws holding the LCD to the frame. 2 on each side.
  6. HP-Compaq G71-329WM LCD Replacement: step 6, image 1 of 1
    • Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
Brent Norris
613 Reputation
1 Guide authored
Brents Computer Repair Member of Brents Computer Repair
Business
1 Member
1 Guide authored
One Comment
Video guide How to disassemble HP Compaq G71 https://youtu.be/TsoP3EdbHz8
Viktorya - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 90
