HTC 7 Surround Camera Replacement
  1. HTC 7 Surround Camera Replacement, Back Case: step 1, image 1 of 2 HTC 7 Surround Camera Replacement, Back Case: step 1, image 2 of 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC 7 Surround Camera Replacement: step 2, image 1 of 3 HTC 7 Surround Camera Replacement: step 2, image 2 of 3 HTC 7 Surround Camera Replacement: step 2, image 3 of 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC 7 Surround Camera Replacement: step 3, image 1 of 1
    • Separate the screen and back cover with the opening tool.
  4. HTC 7 Surround Camera Replacement, Rear Camera: step 4, image 1 of 1
    • The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
    • The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 175
