HTC Desire 530 Battery Replacement
  1. HTC Desire 530 Battery Replacement, Battery: step 1, image 1 of 2 HTC Desire 530 Battery Replacement, Battery: step 1, image 2 of 2
    • Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
    • They may be difficult to peel off and you might want to consider loosening the adhesive layer by running a hair dryer or a heat gun over it briefly to allow them to peel off easily.
  2. HTC Desire 530 Battery Replacement: step 2, image 1 of 3 HTC Desire 530 Battery Replacement: step 2, image 2 of 3 HTC Desire 530 Battery Replacement: step 2, image 3 of 3
    • Use the T5 Torx screwdriver to remove the four screws in each corner.
    • Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
    • Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
  3. HTC Desire 530 Battery Replacement: step 3, image 1 of 3 HTC Desire 530 Battery Replacement: step 3, image 2 of 3 HTC Desire 530 Battery Replacement: step 3, image 3 of 3
    • Dislocate the small piece with the wires connected using a nylon spudger.
    • Loosen the adhesive layer for the battery by running a hair dryer over it briefly. After the adhesive is loosened you can pry the battery out with a plastic opening tool.
  4. HTC Desire 530 Battery Replacement: step 4, image 1 of 2 HTC Desire 530 Battery Replacement: step 4, image 2 of 2
    • After prying, simply lift the battery up and out of the device.
2 other people completed this guide.
Alyssa
205 Reputation
1 Guide authored
UMASSD-PEAK-F18S3G2 Member of UMASSD-PEAK-F18S3G2
Community
3 Members
10 Guides authored
2 Comments
Mi phone is sealed no scrows on my phone HTC Desire 530 so haw can i get the Battery out
robert jelley - Reply
My phone is sealed so awe can i get the Battery out it is HTC desire 530
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 4,277
