HTC Desire 700 Dual Sim Bottom Speaker Replacement
  1. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Back Cover: step 1, image 1 of 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Removing Battery: step 2, image 1 of 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Remove 8 Torx Screws: step 3, image 1 of 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Prying Off Rear Panel: step 4, image 1 of 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Printed Circuit Board (PCB): step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  6. HTC Desire 700 Dual Sim Bottom Speaker Replacement: step 6, image 1 of 1
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
  7. HTC Desire 700 Dual Sim Bottom Speaker Replacement, Bottom Speaker: step 7, image 1 of 1
    • Using the spudger, pry the speaker away from the screen.
3 other people completed this guide.
Steven Pate
191 Reputation
7 Guides authored
USF Tampa, Team 9-3, Blackwell Fall 2014 Member of USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Members
14 Guides authored
One Comment
Mobile spekar
siv kumar - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 889
