HTC Desire 700 Dual Sim Front Facing Camera Replacement
  1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Back Cover: step 1, image 1 of 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Battery: step 2, image 1 of 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Remove 8 Torx Screws: step 3, image 1 of 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Prying Off Rear Panel: step 4, image 1 of 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Motherboard: step 5, image 1 of 1
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Disconnect Vibrator Wire: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. HTC Desire 700 Dual Sim Front Facing Camera Replacement: step 7, image 1 of 1
    • Remove volume control button ribbon with tweezers.
  8. HTC Desire 700 Dual Sim Front Facing Camera Replacement: step 8, image 1 of 1
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. HTC Desire 700 Dual Sim Front Facing Camera Replacement: step 9, image 1 of 1
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
  10. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Camera: step 10, image 1 of 1
    • Remove the camera using the plastic opening tool as shown.
Steven Pate
191 Reputation
7 Guides authored
USF Tampa, Team 9-3, Blackwell Fall 2014 Member of USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 759
