HTC Desire 700 Dual Sim Rear Facing Camera Replacement
  1. HTC Desire 700 Dual Sim Rear Facing Camera Replacement, Back Cover: step 1, image 1 of 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Rear Facing Camera Replacement, Removing Battery: step 2, image 1 of 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Rear Facing Camera Replacement, Remove 8 Torx Screws: step 3, image 1 of 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Rear Facing Camera Replacement, Prying Off Rear Panel: step 4, image 1 of 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Rear Facing Camera Replacement, Motherboard: step 5, image 1 of 1
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. HTC Desire 700 Dual Sim Rear Facing Camera Replacement, Disconnect Vibrator Wire: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. HTC Desire 700 Dual Sim Rear Facing Camera Replacement: step 7, image 1 of 1
    • Remove volume control button ribbon with tweezers.
  8. HTC Desire 700 Dual Sim Rear Facing Camera Replacement: step 8, image 1 of 1
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. HTC Desire 700 Dual Sim Rear Facing Camera Replacement: step 9, image 1 of 1
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
  10. HTC Desire 700 Dual Sim Rear Facing Camera Replacement, Remove Rear Facing Camera: step 10, image 1 of 1
    Buy
    • Carefully remove the ribbon that attaches the camera to the front screen using the tweezers and the plastic opening tool.
Steven Pate
191 Reputation
7 Guides authored
USF Tampa, Team 9-3, Blackwell Fall 2014 Member of USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Members
14 Guides authored
2 Comments
my screen conector on the motherbord got damaged what can i do about it?
stboscoojo - Reply
On step 10, what is that big copper cover? Is it an LNA shield? What is the right tool to remove it?
Thank for this tutorial
Aissa Brahimi - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,380
