HTC Desire 700 Dual Sim Rear Panel Replacement
  1. HTC Desire 700 Dual Sim Rear Panel Replacement, Back Cover: step 1, image 1 of 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Rear Panel Replacement, Removing Battery: step 2, image 1 of 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Rear Panel Replacement, Remove 8 Torx Screws: step 3, image 1 of 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Rear Panel Replacement, Prying Off Rear Panel: step 4, image 1 of 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
Steven Pate
191 Reputation
7 Guides authored
USF Tampa, Team 9-3, Blackwell Fall 2014 Member of USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,380
