HTC Desire HTC Desire Speaker Replacement
Scott Olson
Scott Olson and 2 other contributors
Last updated on October 21, 2021
15 minutes
Moderate
Introduction
Go to step 1
This will show reader how to dissemble the inside of a HTC Desire. It will teach readers how to replace the internal speaker of the phone.
Parts
Tools
Show more…
  1. HTC Desire HTC Desire Speaker Replacement, Battery: step 1, image 1 of 2 HTC Desire HTC Desire Speaker Replacement, Battery: step 1, image 2 of 2
    • Insert flat end of spudger into slot on the top of phone to pry off the back plate.
  2. HTC Desire HTC Desire Speaker Replacement: step 2, image 1 of 2 HTC Desire HTC Desire Speaker Replacement: step 2, image 2 of 2
    • Use flat edge of spudger to lift the bottom right corner of the battery.
    • Lift the battery out of the phone.
  3. HTC Desire HTC Desire Speaker Replacement, Vibrator: step 3, image 1 of 1
    • Remove the lower, two 0.5 mm screws using Torx T5 screwdriver.
  4. HTC Desire HTC Desire Speaker Replacement: step 4, image 1 of 2 HTC Desire HTC Desire Speaker Replacement: step 4, image 2 of 2
    • Use spudger to pry vibrator panel off.
  5. HTC Desire HTC Desire Speaker Replacement: step 5, image 1 of 2 HTC Desire HTC Desire Speaker Replacement: step 5, image 2 of 2
    • Use spudger to remove the vibrator.
  6. HTC Desire HTC Desire Speaker Replacement, HTC Desire Speaker: step 6, image 1 of 2 HTC Desire HTC Desire Speaker Replacement, HTC Desire Speaker: step 6, image 2 of 2
    • Take out the upper, two 0.5 mm Torx screws with a Torx T5 bit.
  7. HTC Desire HTC Desire Speaker Replacement: step 7, image 1 of 1
    • Take the middle 0.3 mm phillips screw out with the phillips J000 tip.
  8. HTC Desire HTC Desire Speaker Replacement: step 8, image 1 of 3 HTC Desire HTC Desire Speaker Replacement: step 8, image 2 of 3 HTC Desire HTC Desire Speaker Replacement: step 8, image 3 of 3
    • Using the spudger, pry up to remove the battery holder.
  9. HTC Desire HTC Desire Speaker Replacement: step 9, image 1 of 3 HTC Desire HTC Desire Speaker Replacement: step 9, image 2 of 3 HTC Desire HTC Desire Speaker Replacement: step 9, image 3 of 3
    • Using the spudger, pry the speaker out of its place.
  10. HTC Desire HTC Desire Speaker Replacement: step 10, image 1 of 1
    • With the springs up, place the new speaker into position.
4 other people completed this guide.
Scott Olson
274 Reputation
1 Guide authored
Montana Tech, Team 10-2, Shirk Fall 2015 Member of Montana Tech, Team 10-2, Shirk Fall 2015
MTUM-SHIRK-F15S10G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,227
