HTC EVO 4G Stand Replacement
  1. HTC EVO 4G Stand Replacement, Battery: step 1, image 1 of 2 HTC EVO 4G Stand Replacement, Battery: step 1, image 2 of 2
    • Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
  2. HTC EVO 4G Stand Replacement: step 2, image 1 of 2 HTC EVO 4G Stand Replacement: step 2, image 2 of 2
    • Remove the battery from the phone by carefully lifting it out with your fingers.
  3. HTC EVO 4G Stand Replacement: step 3, image 1 of 1
    • Set the battery aside for disposal. You are now ready to insert a new battery.
  4. HTC EVO 4G Stand Replacement, Stand: step 4, image 1 of 1
    • you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
  5. HTC EVO 4G Stand Replacement: step 5, image 1 of 3 HTC EVO 4G Stand Replacement: step 5, image 2 of 3 HTC EVO 4G Stand Replacement: step 5, image 3 of 3
    • Using the plastic opening tools again, gently pry the inner frame apart from the rest of the phone
    • Remove the inner frame from the rest of the phone by lifting it off
  6. HTC EVO 4G Stand Replacement: step 6, image 1 of 1
    • Remove the five screws that are holding the stand in place.
  7. HTC EVO 4G Stand Replacement: step 7, image 1 of 1
    • Remove the stand from the frame by lifting it out. Clear any debis causing it to be jammed, or replace with new stand.
Sage Jurado
1,128 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 153
