HTC Flyer Back Cover Replacement
  1. HTC Flyer Back Cover Replacement, Back Cover: step 1, image 1 of 3 HTC Flyer Back Cover Replacement, Back Cover: step 1, image 2 of 3 HTC Flyer Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer Back Cover Replacement: step 2, image 1 of 3 HTC Flyer Back Cover Replacement: step 2, image 2 of 3 HTC Flyer Back Cover Replacement: step 2, image 3 of 3
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer Back Cover Replacement: step 3, image 1 of 3 HTC Flyer Back Cover Replacement: step 3, image 2 of 3 HTC Flyer Back Cover Replacement: step 3, image 3 of 3
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer Back Cover Replacement: step 4, image 1 of 2 HTC Flyer Back Cover Replacement: step 4, image 2 of 2
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
2 other people completed this guide.
Justin Funk
473 Reputation
3 Guides authored
USF Tampa, Team 8-5, Leahy Fall 2014 Member of USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 29
All Time: 600
