HTC Fortress SIM Card Replacement
  1. HTC Fortress SIM Card Replacement, Battery: step 1, image 1 of 2 HTC Fortress SIM Card Replacement, Battery: step 1, image 2 of 2
    • Remove the back cover of the device by sliding it upward.
    • You may need to remove the phone stylus first.
  2. HTC Fortress SIM Card Replacement: step 2, image 1 of 2 HTC Fortress SIM Card Replacement: step 2, image 2 of 2
    • Remove the battery by pulling it away from the back of the phone.
  3. HTC Fortress SIM Card Replacement, SIM Card: step 3, image 1 of 3 HTC Fortress SIM Card Replacement, SIM Card: step 3, image 2 of 3 HTC Fortress SIM Card Replacement, SIM Card: step 3, image 3 of 3
    • Insert the stylus into the small slot.
    • Use the stylus as a lever to push the sim card out of its fitting.
    • Use your finger to slide the card out the rest of the way.
Lucas David
540 Reputation
9 Guides authored
Cal Poly, Team 4-13, Maness Spring 2013 Member of Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 551
