HTC HD 2 Front Panel Replacement
  1. HTC HD 2 Front Panel Replacement, Front panel: step 1, image 1 of 1
    • HTC HD 2 Touch Glas Repair
  2. HTC HD 2 Front Panel Replacement: step 2, image 1 of 1
    • Open the back cover and remove the battery.
  3. HTC HD 2 Front Panel Replacement, These turn out 4 screws: step 3, image 1 of 1
    • Use a small Philips screwdriver to remove the four indicated screws.
  4. HTC HD 2 Front Panel Replacement, Push it out: step 4, image 1 of 1
    • Use a pry tool along the edges of the device to remove the broken or non-functional screen.
  5. HTC HD 2 Front Panel Replacement, Pull flex cable connections and caution.: step 5, image 1 of 3 HTC HD 2 Front Panel Replacement, Pull flex cable connections and caution.: step 5, image 2 of 3 HTC HD 2 Front Panel Replacement, Pull flex cable connections and caution.: step 5, image 3 of 3
    • Carefully pull the flex cable connections.
  6. HTC HD 2 Front Panel Replacement, Nur lösen / Anschluss Flex links von Laut/leise buttons: step 6, image 1 of 3 HTC HD 2 Front Panel Replacement, Nur lösen / Anschluss Flex links von Laut/leise buttons: step 6, image 2 of 3 HTC HD 2 Front Panel Replacement, Nur lösen / Anschluss Flex links von Laut/leise buttons: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Danach 3 tesa stripes lösen
    • Using tweezers, release the 3 tesa strips.
  7. HTC HD 2 Front Panel Replacement: step 7, image 1 of 3 HTC HD 2 Front Panel Replacement: step 7, image 2 of 3 HTC HD 2 Front Panel Replacement: step 7, image 3 of 3
    • Kabel vorsichtig aus dem Kabelschacht ...
    • Carefully remove the cable from its shaft.
  8. HTC HD 2 Front Panel Replacement, Flex: step 8, image 1 of 3 HTC HD 2 Front Panel Replacement, Flex: step 8, image 2 of 3 HTC HD 2 Front Panel Replacement, Flex: step 8, image 3 of 3
    • FLEX
  9. HTC HD 2 Front Panel Replacement, Raushebeln: step 9, image 1 of 3 HTC HD 2 Front Panel Replacement, Raushebeln: step 9, image 2 of 3 HTC HD 2 Front Panel Replacement, Raushebeln: step 9, image 3 of 3
    • Einzelnd
  10. HTC HD 2 Front Panel Replacement, Weiter: step 10, image 1 of 3 HTC HD 2 Front Panel Replacement, Weiter: step 10, image 2 of 3 HTC HD 2 Front Panel Replacement, Weiter: step 10, image 3 of 3
    • Flex
  11. HTC HD 2 Front Panel Replacement, Aufklappen: step 11, image 1 of 3 HTC HD 2 Front Panel Replacement, Aufklappen: step 11, image 2 of 3 HTC HD 2 Front Panel Replacement, Aufklappen: step 11, image 3 of 3
    • Aufklappen
  12. HTC HD 2 Front Panel Replacement, Lösen: step 12, image 1 of 1
    • Vorsichtig
Mark Kruhse
19 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 479
