HTC HD2 Camera Replacement
  1. HTC HD2 Camera Replacement, Battery: step 1, image 1 of 1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Camera Replacement: step 2, image 1 of 2 HTC HD2 Camera Replacement: step 2, image 2 of 2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Camera Replacement, Midframe: step 3, image 1 of 2 HTC HD2 Camera Replacement, Midframe: step 3, image 2 of 2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Camera Replacement: step 4, image 1 of 2 HTC HD2 Camera Replacement: step 4, image 2 of 2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Camera Replacement, Camera: step 5, image 1 of 3 HTC HD2 Camera Replacement, Camera: step 5, image 2 of 3 HTC HD2 Camera Replacement, Camera: step 5, image 3 of 3
    • Disconnect the flash cable from its socket in the bottom of the motherboard.
    • Carefully pull the cable from its groove in the frame, working your way back to the camera.
  6. HTC HD2 Camera Replacement: step 6, image 1 of 3 HTC HD2 Camera Replacement: step 6, image 2 of 3 HTC HD2 Camera Replacement: step 6, image 3 of 3
    • Pull the camera flash and cover off of the board.
    • You may need to peel back the sticker that sits behind the battery.
    • Work carefully. Excessive force can damage the camera or motherboard.
  7. HTC HD2 Camera Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Around the camera is a thin shielding. Remove it with tweezers.
    • Using tweezers, remove the primary camera.
2 other people completed this guide.
Sam Luedloff
727 Reputation
3 Guides authored
Cal Poly, Team 24-55, Amido Spring 2011 Member of Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 8,101
