HTC Maple 100 External Speaker Replacement
  1. HTC Maple 100 External Speaker Replacement, Battery: step 1, image 1 of 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 External Speaker Replacement: step 2, image 1 of 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 External Speaker Replacement: step 3, image 1 of 2 HTC Maple 100 External Speaker Replacement: step 3, image 2 of 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 External Speaker Replacement, Back Panel: step 4, image 1 of 2 HTC Maple 100 External Speaker Replacement, Back Panel: step 4, image 2 of 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 External Speaker Replacement: step 5, image 1 of 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 External Speaker Replacement: step 6, image 1 of 3 HTC Maple 100 External Speaker Replacement: step 6, image 2 of 3 HTC Maple 100 External Speaker Replacement: step 6, image 3 of 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 External Speaker Replacement, External Speaker: step 7, image 1 of 2 HTC Maple 100 External Speaker Replacement, External Speaker: step 7, image 2 of 2
    • Using the plastic opening tool, pry the external speaker out of the back panel.
Alyssa Thompson
11 Reputation
2 Guides authored
Cal Poly, Team 20-29, Maness Fall 2011 Member of Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 873
