HTC One M8 Display Assembly Replacement
  1. HTC One M8 Display Assembly Replacement, SIM Card: step 1, image 1 of 2 HTC One M8 Display Assembly Replacement, SIM Card: step 1, image 2 of 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. HTC One M8 Display Assembly Replacement: step 2, image 1 of 1
    • Remove the SIM card tray assembly from the HTC One M8.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. HTC One M8 Display Assembly Replacement, MicroSD Card: step 3, image 1 of 2 HTC One M8 Display Assembly Replacement, MicroSD Card: step 3, image 2 of 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone.
  4. HTC One M8 Display Assembly Replacement: step 4, image 1 of 1
    • Remove the microSD card tray assembly from the HTC One M8.
    • When reinserting the microSD card, ensure that it is in the proper orientation relative to the tray.
  5. HTC One M8 Display Assembly Replacement, Rear Case: step 5, image 1 of 2 HTC One M8 Display Assembly Replacement, Rear Case: step 5, image 2 of 2
    • Use an iOpener or heat gun to loosen the adhesive on the upper and lower speaker grilles.
    • Refer to the iOpener guide for info on how to use the iOpener.
  6. HTC One M8 Display Assembly Replacement: step 6, image 1 of 3 HTC One M8 Display Assembly Replacement: step 6, image 2 of 3 HTC One M8 Display Assembly Replacement: step 6, image 3 of 3
    • Use a plastic opening tool to gently peel up the lower speaker grille.
    • The adhesive is messy, and can be removed using Goo-gone.
  7. HTC One M8 Display Assembly Replacement: step 7, image 1 of 2 HTC One M8 Display Assembly Replacement: step 7, image 2 of 2
    • Use a plastic opening tool to gently peel up the upper speaker grille.
  8. HTC One M8 Display Assembly Replacement: step 8, image 1 of 1
    • Remove the two silver 3 mm Phillips #00 screws from the top.
    • Remove the four black 4 mm T5 Torx screws from the bottom.
  9. HTC One M8 Display Assembly Replacement: step 9, image 1 of 3 HTC One M8 Display Assembly Replacement: step 9, image 2 of 3 HTC One M8 Display Assembly Replacement: step 9, image 3 of 3
    • Work your way around the perimeter of the phone with a spudger and plastic opening picks to free the clips that secure the rear case to the display assembly.
    • A metal spudger is pictured, but it is best to use a nylon spudger to prevent marring the device.
    • Be careful not to lose the power button: it sits loosely in the top of the lower chassis.
    • Significant force may be required to pry the casing apart.
  10. HTC One M8 Display Assembly Replacement, Headphone Jack/Micro USB Board: step 10, image 1 of 2 HTC One M8 Display Assembly Replacement, Headphone Jack/Micro USB Board: step 10, image 2 of 2
    • Remove the two silver 2mm Phillips #00 screws securing the battery connector to the motherboard.
    • Use a plastic opening tool to gently pry up the battery connector.
  11. HTC One M8 Display Assembly Replacement: step 11, image 1 of 3 HTC One M8 Display Assembly Replacement: step 11, image 2 of 3 HTC One M8 Display Assembly Replacement: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Use a spudger to disconnect the two ZIF connectors.
    • Use the flat end of a spudger to disconnect the black antenna cable.
    • Use a set of tweezers to pull the two ribbon cables free of the ZIF connectors.
  12. HTC One M8 Display Assembly Replacement: step 12, image 1 of 3 HTC One M8 Display Assembly Replacement: step 12, image 2 of 3 HTC One M8 Display Assembly Replacement: step 12, image 3 of 3
    • Remove the single silver 4mm T5 Torx screw securing the headphone jack/micro USB board.
    • You may need to gently bend the small ribbon cable out of the way to get to the screw.
    • Use a pair of tweezers or a plastic opening tool to gently pry the headphone jack/micro USB board up and out of the phone.
  13. HTC One M8 Display Assembly Replacement, Display Assembly: step 13, image 1 of 3 HTC One M8 Display Assembly Replacement, Display Assembly: step 13, image 2 of 3 HTC One M8 Display Assembly Replacement, Display Assembly: step 13, image 3 of 3
    Buy
    • Use the tip of a spudger to disconnect the seven ZIF connectors.
    • Use a pair of tweezers to gently pull the seven ribbon cables free of the connectors.
  14. HTC One M8 Display Assembly Replacement: step 14, image 1 of 3 HTC One M8 Display Assembly Replacement: step 14, image 2 of 3 HTC One M8 Display Assembly Replacement: step 14, image 3 of 3
    • Use an iOpener to loosen the adhesive securing the display assembly to the rest of the device.
    • Use a suction cup to gently separate the display assembly from the rest of the device.
  15. HTC One M8 Display Assembly Replacement: step 15, image 1 of 3 HTC One M8 Display Assembly Replacement: step 15, image 2 of 3 HTC One M8 Display Assembly Replacement: step 15, image 3 of 3
    • Carefully guide the display assembly ribbon cable through the midframe for removal.
70 other people completed this guide.
Michael Gonzalez
4,439 Reputation
5 Guides authored
Cal Poly, Team 5-9, Maness Spring 2015 Member of Cal Poly, Team 5-9, Maness Spring 2015
CPSU-MANESS-S15S5G9
4 Members
18 Guides authored
10 Guide Comments
Great guide - many thanks!
In step 13, you only need to disconnect four ZIF connectors - the top two on the left and top one on the right can be left connected.
Thanks again!
Byrn
Byrn - Reply Share
Be careful when reassembling:
Make sure the power button is put in the right way, it may look symmetrical but it's not! When put in the wrong way it does not work. Check if the shape of the button aligns with the edge of the casing, it's pretty easy to see if you pay attention to it.
Also keep an eye on the back camera. The round black cover glass may shift when trying to click the phone in its casing.
I ended up taking it apart at least 4 times because of this :(
Also, if you want to heat things up you can also use an incandescent light bulb and put your phone over it.
Jan de Vries - Reply Share
position of the square block on the power button is a little bit left from the center (phone facing you with screen)
AG Draaijer - Share
don't follow step 13 in fact &&^& this guide listen to byrn
DeAndre Barron - Reply Share
very helpful, thanks
Stuart Gilks - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 124
All Time: 55,348
