HTC One Max Battery Replacement
  1. HTC One Max Battery Replacement, Back Case: step 1, image 1 of 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Battery Replacement: step 2, image 1 of 2 HTC One Max Battery Replacement: step 2, image 2 of 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Battery Replacement: step 3, image 1 of 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Battery Replacement: step 4, image 1 of 2 HTC One Max Battery Replacement: step 4, image 2 of 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Battery Replacement, Fingerprint Sensor: step 5, image 1 of 2 HTC One Max Battery Replacement, Fingerprint Sensor: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  6. HTC One Max Battery Replacement, Motherboard: step 6, image 1 of 2 HTC One Max Battery Replacement, Motherboard: step 6, image 2 of 2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
  7. HTC One Max Battery Replacement: step 7, image 1 of 2 HTC One Max Battery Replacement: step 7, image 2 of 2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
  8. HTC One Max Battery Replacement: step 8, image 1 of 1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
  9. HTC One Max Battery Replacement: step 9, image 1 of 3 HTC One Max Battery Replacement: step 9, image 2 of 3 HTC One Max Battery Replacement: step 9, image 3 of 3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  10. HTC One Max Battery Replacement: step 10, image 1 of 3 HTC One Max Battery Replacement: step 10, image 2 of 3 HTC One Max Battery Replacement: step 10, image 3 of 3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
  11. HTC One Max Battery Replacement: step 11, image 1 of 2 HTC One Max Battery Replacement: step 11, image 2 of 2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
  12. HTC One Max Battery Replacement, IR Blaster: step 12, image 1 of 1
    • Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
  13. HTC One Max Battery Replacement: step 13, image 1 of 1
    • Pick up and set aside vibrator, do not disconnect.
  14. HTC One Max Battery Replacement: step 14, image 1 of 1
    • Pull out ribbon cable.
    • Peel back infrared sensor.
  15. HTC One Max Battery Replacement, Camera Board: step 15, image 1 of 2 HTC One Max Battery Replacement, Camera Board: step 15, image 2 of 2
    • Pull out the secondary board with the camera attached.
    • Be advised of the adhesive on the back.
  16. HTC One Max Battery Replacement, Remove Bottom Screws: step 16, image 1 of 1
    • Remove two screws from the bottom.
    • Set aside metal retaining plate.
  17. HTC One Max Battery Replacement, Speaker Assembly: step 17, image 1 of 2 HTC One Max Battery Replacement, Speaker Assembly: step 17, image 2 of 2
    • Pry back the speaker and microphone assembly from the bottom.
    • Be careful to not poke the speaker.
  18. HTC One Max Battery Replacement, Remove Battery: step 18, image 1 of 3 HTC One Max Battery Replacement, Remove Battery: step 18, image 2 of 3 HTC One Max Battery Replacement, Remove Battery: step 18, image 3 of 3
    • Pry the battery away from the back of the screen with a plastic tool.
    • We recommend using a heat gun to loosen the adhesive holding the battery in place.
15 other people completed this guide.
Andrey Sklyar
452 Reputation
2 Guides authored
USF Tampa, Team 11-3, Blackwell Fall 2014 Member of USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Members
7 Guides authored
4 Guide Comments
Microphone in the article, battery in the title.
AaronAndrusko - Reply Share
How to change LCD screen for this model?
Jembalang Tanah - Reply Share
What the &&^& man i prefer to buy another phone %#*@ it
Russel - Reply Share
What the &&^& man i prefer to buy a new phone
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 53
All Time: 15,941
