HTC One Max Fingerprint Sensor Replacement
  1. HTC One Max Fingerprint Sensor Replacement, Back Case: step 1, image 1 of 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Fingerprint Sensor Replacement: step 2, image 1 of 2 HTC One Max Fingerprint Sensor Replacement: step 2, image 2 of 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Fingerprint Sensor Replacement: step 3, image 1 of 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Fingerprint Sensor Replacement: step 4, image 1 of 2 HTC One Max Fingerprint Sensor Replacement: step 4, image 2 of 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: step 5, image 1 of 2 HTC One Max Fingerprint Sensor Replacement, Fingerprint Sensor: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
Andrey Sklyar
452 Reputation
2 Guides authored
USF Tampa, Team 11-3, Blackwell Fall 2014 Member of USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,375
