HTC One Max Motherboard Replacement
  1. HTC One Max Motherboard Replacement, Back Case: step 1, image 1 of 1
    • Lift back cover while pressing highlighted release switch towards the center of the phone.
  2. HTC One Max Motherboard Replacement: step 2, image 1 of 2 HTC One Max Motherboard Replacement: step 2, image 2 of 2
    • Remove the four white stickers in each corner that cover the Tri-Wing screws.
    • Remove the white sticker near the buttons that control the volume.
    • Remove the white sticker near the SIM card.
    • Remove the big white sticker with the bar-code in the center of the phone.
  3. HTC One Max Motherboard Replacement: step 3, image 1 of 1
    • Remove the thirteen Tri-Wing Y00 screws (Upper & Lower screws are 5 mm length, middle screws are 3.8 mm length) from the back case.
    • Disconnect the cable near the volume buttons.
  4. HTC One Max Motherboard Replacement: step 4, image 1 of 2 HTC One Max Motherboard Replacement: step 4, image 2 of 2
    • Use the small plastic opening tool to pry between the screen and the rear case.
  5. HTC One Max Motherboard Replacement, Fingerprint Sensor: step 5, image 1 of 2 HTC One Max Motherboard Replacement, Fingerprint Sensor: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use Tweezers to disconnect the ribbon cable connecting the fingerprint sensor to the motherboard.
    • When replacing the fingerprint sensor, make sure the ribbon cable snaps into the port on the motherboard.
  6. HTC One Max Motherboard Replacement, Motherboard: step 6, image 1 of 2 HTC One Max Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
    • Use a plastic tool to remove the ribbon cable.
  7. HTC One Max Motherboard Replacement: step 7, image 1 of 2 HTC One Max Motherboard Replacement: step 7, image 2 of 2
    • Use the plastic opening tool to disconnect the two antenna wires at the top of the phone.
    • Use the plastic opening tool to disconnect a third antenna wire at the bottom of the phone.
  8. HTC One Max Motherboard Replacement: step 8, image 1 of 1
    • Remove the seven 3 mm Phillips #000 screws from the motherboard.
  9. HTC One Max Motherboard Replacement: step 9, image 1 of 3 HTC One Max Motherboard Replacement: step 9, image 2 of 3 HTC One Max Motherboard Replacement: step 9, image 3 of 3
    • Use a plastic tool to pry up and disconnect the large ribbon cables on each side of the motherboard.
    • Use caution prying the ribbon cable on the right side because other ribbon cables run under it.
  10. HTC One Max Motherboard Replacement: step 10, image 1 of 3 HTC One Max Motherboard Replacement: step 10, image 2 of 3 HTC One Max Motherboard Replacement: step 10, image 3 of 3
    • Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
    • Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
  11. HTC One Max Motherboard Replacement: step 11, image 1 of 2 HTC One Max Motherboard Replacement: step 11, image 2 of 2
    • Use a plastic tool to lift and remove the motherboard.
    • Use a heat gun to loosen adhesive at bottom if needed.
6 other people completed this guide.
Andrew Keller
1,131 Reputation
5 Guides authored
USF Tampa, Team 11-3, Blackwell Fall 2014 Member of USF Tampa, Team 11-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G3
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 18
All Time: 5,810
