HTC One Mini 2 Rumble Motor Replacement
  1. HTC One Mini 2 Rumble Motor Replacement, Sim and MicroSD Card: step 1, image 1 of 3 HTC One Mini 2 Rumble Motor Replacement, Sim and MicroSD Card: step 1, image 2 of 3 HTC One Mini 2 Rumble Motor Replacement, Sim and MicroSD Card: step 1, image 3 of 3
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
  2. HTC One Mini 2 Rumble Motor Replacement: step 2, image 1 of 1
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
  3. HTC One Mini 2 Rumble Motor Replacement, Front Plate: step 3, image 1 of 3 HTC One Mini 2 Rumble Motor Replacement, Front Plate: step 3, image 2 of 3 HTC One Mini 2 Rumble Motor Replacement, Front Plate: step 3, image 3 of 3
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
  4. HTC One Mini 2 Rumble Motor Replacement: step 4, image 1 of 2 HTC One Mini 2 Rumble Motor Replacement: step 4, image 2 of 2
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
  5. HTC One Mini 2 Rumble Motor Replacement: step 5, image 1 of 2 HTC One Mini 2 Rumble Motor Replacement: step 5, image 2 of 2
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
  6. HTC One Mini 2 Rumble Motor Replacement, Motherboard: step 6, image 1 of 2 HTC One Mini 2 Rumble Motor Replacement, Motherboard: step 6, image 2 of 2
    • Peel off the long yellow pieces of tape on the right and left side of the copper plate.
  7. HTC One Mini 2 Rumble Motor Replacement: step 7, image 1 of 1
    • Starting from the copper plate, peel up all three woven, silver colored tapes using the spudger or narrow pry tool.
  8. HTC One Mini 2 Rumble Motor Replacement: step 8, image 1 of 3 HTC One Mini 2 Rumble Motor Replacement: step 8, image 2 of 3 HTC One Mini 2 Rumble Motor Replacement: step 8, image 3 of 3
    • Using the flat end of the spudger, pop up the white tabs on all ribbon cable connectors located to the left and right of the copper plate.
    • On the left side, pop the white tab up to the left. On the right, pop up to the right.
    • Carefully pull out the ribbon cables.
  9. HTC One Mini 2 Rumble Motor Replacement: step 9, image 1 of 3 HTC One Mini 2 Rumble Motor Replacement: step 9, image 2 of 3 HTC One Mini 2 Rumble Motor Replacement: step 9, image 3 of 3
    • Using a Phillips #00 screwdriver, unscrew the two 1 mm screws from the bottom right corner of the motherboard that hold the power connector down.
    • Pop up the battery connector using the flat end of the spudger.
  10. HTC One Mini 2 Rumble Motor Replacement: step 10, image 1 of 3 HTC One Mini 2 Rumble Motor Replacement: step 10, image 2 of 3 HTC One Mini 2 Rumble Motor Replacement: step 10, image 3 of 3
    • Use the pointed end of the spudger to pop off the four antenna connectors. Three are located on the top left corner of the motherboard and one on the bottom right.
  11. HTC One Mini 2 Rumble Motor Replacement: step 11, image 1 of 2 HTC One Mini 2 Rumble Motor Replacement: step 11, image 2 of 2
    • Using the pointed end of the spudger, pull the wires for the rumble motor to the left to pull the connector out of the board.
    • The connector is very small and easy to break so take caution when pulling it out. Wiggling the wires as you pull to the left helps.
  12. HTC One Mini 2 Rumble Motor Replacement: step 12, image 1 of 3 HTC One Mini 2 Rumble Motor Replacement: step 12, image 2 of 3 HTC One Mini 2 Rumble Motor Replacement: step 12, image 3 of 3
    • Using a T5 torx screwdriver, remove four 2mm screws from the four corners of the motherboard.
    • Once the screws are removed, carefully pull the copper plated motherboard out.
  13. HTC One Mini 2 Rumble Motor Replacement, Rumble Motor: step 13, image 1 of 1
    • Using the narrow plastic prying tool, pry up the rectangle connector covered in black foam
  14. HTC One Mini 2 Rumble Motor Replacement: step 14, image 1 of 1
    • Use the pointed end of the spudger to pop the rumble motor out of its housing.
Jeron Hogan
818 Reputation
3 Guides authored
Cal Poly, Team 4-48, Amido Fall 2014 Member of Cal Poly, Team 4-48, Amido Fall 2014
CPSU-AMIDO-F14S4G48
5 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 2,525
