HTC One Mini LCD Display Replacement
  1. HTC One Mini LCD Display Replacement, iOpener Heating: step 1, image 1 of 1
    • Use the iOpener to melt the glue off of the top and bottom speaker grills.
  2. HTC One Mini LCD Display Replacement, Remove Speaker Grills: step 2, image 1 of 1
    • Use the blue plastic opening tool to pry and remove the bottom speaker grill.
  3. HTC One Mini LCD Display Replacement, Remove Screw: step 3, image 1 of 3 HTC One Mini LCD Display Replacement, Remove Screw: step 3, image 2 of 3 HTC One Mini LCD Display Replacement, Remove Screw: step 3, image 3 of 3
    • Remove the screw under speaker grill using a T6 Torx screwdriver.
  4. HTC One Mini LCD Display Replacement: step 4, image 1 of 3 HTC One Mini LCD Display Replacement: step 4, image 2 of 3 HTC One Mini LCD Display Replacement: step 4, image 3 of 3
    • Wedge the plastic opening tool between the screen and the edge of the case.
    • Use force to pry and separate the rear panel.
  5. HTC One Mini LCD Display Replacement, Separate Rear Case: step 5, image 1 of 2 HTC One Mini LCD Display Replacement, Separate Rear Case: step 5, image 2 of 2
    • Separate the rear panel from the phone.
  6. HTC One Mini LCD Display Replacement: step 6, image 1 of 2 HTC One Mini LCD Display Replacement: step 6, image 2 of 2
    • Using the plastic opening tool, pry on the screen to separate it from the adhesive holding it.
  7. HTC One Mini LCD Display Replacement, Separate LCD Screen: step 7, image 1 of 2 HTC One Mini LCD Display Replacement, Separate LCD Screen: step 7, image 2 of 2
    • After you have used the opening tool to pry, use some force to separate the LCD screen from the glue.
12 other people completed this guide.
Chris Jose
735 Reputation
2 Guides authored
USF Tampa, Team 3-4, Brown Fall 2014 Member of USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Members
10 Guides authored
2 Guide Comments
I have bought a new lcd digitizer for an htc m8 mini 2….I've assemble it and when i have turned the power on all i got was a light coming on… no displays on the screen…what could be the issue??
Ramon Alex Headley - Reply
Is it easier to fix if only the screen glass is broken and not the LCD?
myshepherd - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 48,788
