HTC One Speaker Replacement
  1. HTC One Speaker Replacement, Speaker: step 1, image 1 of 3 HTC One Speaker Replacement, Speaker: step 1, image 2 of 3 HTC One Speaker Replacement, Speaker: step 1, image 3 of 3
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: step 2, image 1 of 1
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: step 3, image 1 of 1
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: step 5, image 1 of 1
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: step 6, image 1 of 2 HTC One Speaker Replacement: step 6, image 2 of 2
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: step 7, image 1 of 2 HTC One Speaker Replacement: step 7, image 2 of 2
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: step 8, image 1 of 3 HTC One Speaker Replacement: step 8, image 2 of 3 HTC One Speaker Replacement: step 8, image 3 of 3
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: step 9, image 1 of 2 HTC One Speaker Replacement: step 9, image 2 of 2
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
16 other people completed this guide.
Alex
664 Reputation
1 Guide authored
USF Tampa, Team 12-1, Blackwell Fall 2014 Member of USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 Members
7 Guides authored
2 Guide Comments
Ok I will good
Raguraman - Reply
Where to buy speaker???
bharatdshmkh - Reply
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 42
All Time: 19,766
