HTC One V Loudspeaker Replacement
  1. HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 1 of 3 HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 2 of 3 HTC One V Loudspeaker Replacement, Disassembling HTC ONE V Bottom Assembly: step 1, image 3 of 3
    • Power off your device.
    • Remove the bottom cover by sliding it off.
  2. HTC One V Loudspeaker Replacement: step 2, image 1 of 1
    • Remove the SIM card.
    • Remove the four screws securing the bottom casing.
    • Two 3.0 mm Phillips #0 screws in the top left and right corners.
    • Two 2.0 mm Phillips #0 screws in the bottom left and right corners.
  3. HTC One V Loudspeaker Replacement: step 3, image 1 of 2 HTC One V Loudspeaker Replacement: step 3, image 2 of 2
    • Remove the 2.0 mm Phillips #0 screws on either side of the phone.
  4. HTC One V Loudspeaker Replacement: step 4, image 1 of 3 HTC One V Loudspeaker Replacement: step 4, image 2 of 3 HTC One V Loudspeaker Replacement: step 4, image 3 of 3
    • Use a plastic opening tool to pry open the bottom casing.
    • Remove the bottom casing by pulling it towards you.
  5. HTC One V Loudspeaker Replacement, Loudspeaker: step 5, image 1 of 2 HTC One V Loudspeaker Replacement, Loudspeaker: step 5, image 2 of 2
    • Using a plastic opening tool, peel off the speaker cover.
  6. HTC One V Loudspeaker Replacement: step 6, image 1 of 1
    • Use the spudger to push the speaker out of its casing.
abebe alemu
101 Reputation
1 Guide authored
USF Tampa, Team 1-3, Blackwell Winter 2015 Member of USF Tampa, Team 1-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G3
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 476
