HTC One X Plus Battery Replacement
  1. HTC One X Plus Battery Replacement, Battery: step 1, image 1 of 1
    • Power off your device.
    • Insert a pin, paper clip, or very small piece of metal into the hole next to the micro SIM card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Battery Replacement: step 2, image 1 of 3 HTC One X Plus Battery Replacement: step 2, image 2 of 3 HTC One X Plus Battery Replacement: step 2, image 3 of 3
    • Using plastic opening tools, pry open the bottom of the device first.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Battery Replacement: step 3, image 1 of 3 HTC One X Plus Battery Replacement: step 3, image 2 of 3 HTC One X Plus Battery Replacement: step 3, image 3 of 3
    • Remove the five 2.4mm screws using a Phillips head screw driver and then remove the plastic cover.
  4. HTC One X Plus Battery Replacement: step 4, image 1 of 3 HTC One X Plus Battery Replacement: step 4, image 2 of 3 HTC One X Plus Battery Replacement: step 4, image 3 of 3
    • Remove the two 3.4 mm JIS #000 screws from the PCB board.
    • Remove the PCB board and antenna.
  5. HTC One X Plus Battery Replacement: step 5, image 1 of 2 HTC One X Plus Battery Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to disconnect the power button flex cable.
    • Disconnect the touch screen flex cable
  6. HTC One X Plus Battery Replacement: step 6, image 1 of 3 HTC One X Plus Battery Replacement: step 6, image 2 of 3 HTC One X Plus Battery Replacement: step 6, image 3 of 3
    • Disconnect the battery from the logic board by detaching the six pin connector.
    • Remove the battery by pulling upwards.
3 other people completed this guide.
Vitterio Crisp
119 Reputation
1 Guide authored
USF Tampa, Team 3-3, Eyestone Fall 2015 Member of USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 4,266
