HTC One X SIM Card Tray Replacement
  1. HTC One X SIM Card Tray Replacement, SIM Card Tray: step 1, image 1 of 1
    • Insert a safety pin or other small object in the small opening next to the SIM card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
  2. HTC One X SIM Card Tray Replacement, Repair SIM card tray: step 2, image 1 of 1
    • Cut a piece of tape/ paper approximately the size of your Sim Card and secure it to the back side of the Sim. Be sure to trim any excess.
    • It's important that you place the tape on the back side of the Sim Card as it will block the communication with the device if placed on the front side
    • Slowly slide the Sim Card tray back into the device. It should be a smooth transition, don't force the tray in.
    • If the tray is still loose you can keep adding tape/paper until it's no longer loose.
5 other people completed this guide.
Blain Abebe
766 Reputation
3 Guides authored
USF Tampa, Team 4-3, Brown Fall 2014 Member of USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 43
All Time: 7,298
