HTC One X Screen Replacement
  1. HTC One X Screen Replacement, Remove SIM card slot: step 1, image 1 of 1
    • Insert a safety pin, or other small object in the small opening next to the Sim card slot to remove the SIM card.
    • The Sim Card Slot is located at the top of the rear panel.
  2. HTC One X Screen Replacement, Remove front panel: step 2, image 1 of 2 HTC One X Screen Replacement, Remove front panel: step 2, image 2 of 2
    • Using a plastic opening tool, carefully separate the display screen from the rear panel.
    • The display assembly is a tight fit therefore the removal must be carried out carefully with firm, constant force being applied around the bottom corners and sides of the panel. Note that the top of the phone is underneath the panel, and will not come out.
    • If your display is cracked, take extra caution when separating the display from the rear panel to prevent further breakage.
    • Set aside the rear panel.
  3. HTC One X Screen Replacement, Remove the top plastic panel: step 3, image 1 of 2 HTC One X Screen Replacement, Remove the top plastic panel: step 3, image 2 of 2
    • Remove the five screws at the top of the panel using a Phillips head screwdriver.
    • Two 2.05mm Philips head screws
    • Three 2.44mm Philips head screws
    • Also remove the screws with the warranty stickers.
    • Once the screws are removed, gently remove the plastic cover using a plastic opening tool to detach the edges from the front panel.
    • Once you have disassembled your device, your warranty will no longer be valid.
  4. HTC One X Screen Replacement, Remove antenna and disconnect the PCB board: step 4, image 1 of 2 HTC One X Screen Replacement, Remove antenna and disconnect the PCB board: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the two screws at the bottom right corner of the front panel using a Phillips head screwdriver, as shown in the image.
    • Two 3.35mm Philips head screws
    • Use tweezers to disconnect the antenna from the logic board to the PCB board.
    • Remove the tape connected to the motherboard.
  5. HTC One X Screen Replacement, Disconnect the battery and remove PCB board: step 5, image 1 of 3 HTC One X Screen Replacement, Disconnect the battery and remove PCB board: step 5, image 2 of 3 HTC One X Screen Replacement, Disconnect the battery and remove PCB board: step 5, image 3 of 3
    • Remove the tape holding the battery in place.
    • Gently lift the battery from the bottom using a plastic opening tool.
    • You may have to apply heat to melt the glue holding the battery in place.
    • Do not completely remove the battery yet
    • You can now disconnect the flex cable holding the PCB board place. Gently open the gates using tweezers or a plastic opening tool and use tweezers to slide the flex cable out.
    • Now that it's separated, remove and set aside the PCB board.
  6. HTC One X Screen Replacement, Disconnect flex cables: step 6, image 1 of 3 HTC One X Screen Replacement, Disconnect flex cables: step 6, image 2 of 3 HTC One X Screen Replacement, Disconnect flex cables: step 6, image 3 of 3
    • Place the battery back into its original position once the PCB board has been removed
    • Use tweezers to disconnect the power button flex cables.
    • Disconnect the volume flex cable by opening the gate and then sliding the cable out using tweezers.
    • Disconnect the touchscreen flex cable
    • If repairing hard buttons, skip step 7.
  7. HTC One X Screen Replacement, Remove logic board: step 7, image 1 of 1
    • Disconnect the remaining two flex cables in a similar manner before completely removing the logic board.
    • You may now remove the board safely
  8. HTC One X Screen Replacement, Disconnecting the digitizer and screen: step 8, image 1 of 2 HTC One X Screen Replacement, Disconnecting the digitizer and screen: step 8, image 2 of 2
    • You must now disconnect the screen and digitzer, which are glued together.
    • You may need to use hot air to heat up the adhesive keeping the screen and digitizer together. This will make separating them much easier.
    • Using a plastic opening tool, slip the tool between the screen and the digitizer and slowly pry them apart.
    • After this is complete, orient your new screen in the same manner as the old one, attach it to the digitizer with a strong adhesive, and reassemble.
15 other people completed this guide.
Liam
252 Reputation
1 Guide authored
USF Tampa, Team 4-3, Brown Fall 2014 Member of USF Tampa, Team 4-3, Brown Fall 2014
USFT-BROWN-F14S4G3
3 Members
12 Guides authored
1 Guide Comment
Changing screen is not changing glass.
Screen = glass and lcd....
iffbas - Reply
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 29
All Time: 16,255
