HTC Ozone Keyboard Replacement
  1. HTC Ozone Keyboard Replacement, Rear Battery Cover: step 1, image 1 of 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Keyboard Replacement: step 2, image 1 of 2 HTC Ozone Keyboard Replacement: step 2, image 2 of 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Keyboard Replacement, Battery: step 3, image 1 of 3 HTC Ozone Keyboard Replacement, Battery: step 3, image 2 of 3 HTC Ozone Keyboard Replacement, Battery: step 3, image 3 of 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Keyboard Replacement, Frame: step 4, image 1 of 2 HTC Ozone Keyboard Replacement, Frame: step 4, image 2 of 2
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Keyboard Replacement: step 5, image 1 of 3 HTC Ozone Keyboard Replacement: step 5, image 2 of 3 HTC Ozone Keyboard Replacement: step 5, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Keyboard Replacement, Motherboard: step 6, image 1 of 2 HTC Ozone Keyboard Replacement, Motherboard: step 6, image 2 of 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Keyboard Replacement: step 7, image 1 of 2 HTC Ozone Keyboard Replacement: step 7, image 2 of 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Keyboard Replacement: step 8, image 1 of 3 HTC Ozone Keyboard Replacement: step 8, image 2 of 3 HTC Ozone Keyboard Replacement: step 8, image 3 of 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
  9. HTC Ozone Keyboard Replacement, LCD Display: step 9, image 1 of 2 HTC Ozone Keyboard Replacement, LCD Display: step 9, image 2 of 2
    • Remove the gray tape securing the ribbon cable.
  10. HTC Ozone Keyboard Replacement: step 10, image 1 of 1
    • Remove the yellow tape securing the connector lock.
  11. HTC Ozone Keyboard Replacement: step 11, image 1 of 2 HTC Ozone Keyboard Replacement: step 11, image 2 of 2
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
  12. HTC Ozone Keyboard Replacement: step 12, image 1 of 1
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
  13. HTC Ozone Keyboard Replacement: step 13, image 1 of 1
    • Lift the Motherboard away from the LCD display.
  14. HTC Ozone Keyboard Replacement, Keyboard: step 14, image 1 of 2 HTC Ozone Keyboard Replacement, Keyboard: step 14, image 2 of 2
    • Lift off main keyboard from front plastic case using plastic opening tool.
  15. HTC Ozone Keyboard Replacement: step 15, image 1 of 2 HTC Ozone Keyboard Replacement: step 15, image 2 of 2
    • Remove four Phillips #00 screws securing function keys.
  16. HTC Ozone Keyboard Replacement: step 16, image 1 of 2 HTC Ozone Keyboard Replacement: step 16, image 2 of 2
    • Pop keys out by pushing keys from back of the phone.
Marco Jokada
247 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,879
