HTC Ozone Motherboard Replacement
  1. HTC Ozone Motherboard Replacement, Rear Battery Cover: step 1, image 1 of 1
    • Flip the phone over to have the rear cover facing up.
    • The camera lens should be towards the top of the phone.
  2. HTC Ozone Motherboard Replacement: step 2, image 1 of 2 HTC Ozone Motherboard Replacement: step 2, image 2 of 2
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
  3. HTC Ozone Motherboard Replacement, Battery: step 3, image 1 of 3 HTC Ozone Motherboard Replacement, Battery: step 3, image 2 of 3 HTC Ozone Motherboard Replacement, Battery: step 3, image 3 of 3
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
  4. HTC Ozone Motherboard Replacement, Frame: step 4, image 1 of 2 HTC Ozone Motherboard Replacement, Frame: step 4, image 2 of 2
    • Remove the six Torx #5 screws that are securing the rear frame.
  5. HTC Ozone Motherboard Replacement: step 5, image 1 of 3 HTC Ozone Motherboard Replacement: step 5, image 2 of 3 HTC Ozone Motherboard Replacement: step 5, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
    • A plastic card can be used instead of the plastic opening tool.
  6. HTC Ozone Motherboard Replacement, Motherboard: step 6, image 1 of 2 HTC Ozone Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
  7. HTC Ozone Motherboard Replacement: step 7, image 1 of 2 HTC Ozone Motherboard Replacement: step 7, image 2 of 2
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
    • Be careful not to break the ribbon cable when prying away the motherboard.
  8. HTC Ozone Motherboard Replacement: step 8, image 1 of 3 HTC Ozone Motherboard Replacement: step 8, image 2 of 3 HTC Ozone Motherboard Replacement: step 8, image 3 of 3
    • Remove the plastic cover from the LCD display and the motherboard.
    • The Motherboard and the LCD are still attached together.
Marco Jokada
247 Reputation
6 Guides authored
1 Guide Comment
Where can I buy/find/get this motherboard? I have been looking for one for over a year now, thanks
Walt - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 41
All Time: 1,725
