HTC Rhyme charging port Replacement
  1. HTC Rhyme charging port Replacement, Charging Port: step 1, image 1 of 2 HTC Rhyme charging port Replacement, Charging Port: step 1, image 2 of 2
    • Image of the front and back of the HTC Rhyme.
  2. HTC Rhyme charging port Replacement: step 2, image 1 of 3 HTC Rhyme charging port Replacement: step 2, image 2 of 3 HTC Rhyme charging port Replacement: step 2, image 3 of 3
    • Remove the back cover by pulling down on the lower half.
  3. HTC Rhyme charging port Replacement: step 3, image 1 of 3 HTC Rhyme charging port Replacement: step 3, image 2 of 3 HTC Rhyme charging port Replacement: step 3, image 3 of 3
    • Use a T5 to remove the five highlighted screws in the image.
  4. HTC Rhyme charging port Replacement: step 4, image 1 of 2 HTC Rhyme charging port Replacement: step 4, image 2 of 2
    • Once the screws are removed, slide the back cover off of the phone.
  5. HTC Rhyme charging port Replacement: step 5, image 1 of 3 HTC Rhyme charging port Replacement: step 5, image 2 of 3 HTC Rhyme charging port Replacement: step 5, image 3 of 3
    • Remove the two screws highlighted in the image with a Phillips screwdriver.
  6. HTC Rhyme charging port Replacement: step 6, image 1 of 2 HTC Rhyme charging port Replacement: step 6, image 2 of 2
    • Push off the small silver piece resting above the charging port.
  7. HTC Rhyme charging port Replacement: step 7, image 1 of 3 HTC Rhyme charging port Replacement: step 7, image 2 of 3 HTC Rhyme charging port Replacement: step 7, image 3 of 3
    • Disconnect the black cable on the upper right side of the motherboard.
  8. HTC Rhyme charging port Replacement: step 8, image 1 of 3 HTC Rhyme charging port Replacement: step 8, image 2 of 3 HTC Rhyme charging port Replacement: step 8, image 3 of 3
    • Disconnect the green cables in the upper center section of the motherboard.
  9. HTC Rhyme charging port Replacement: step 9, image 1 of 3 HTC Rhyme charging port Replacement: step 9, image 2 of 3 HTC Rhyme charging port Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the yellow cable by gently pulling on it with tweezers.
    • When assembling, use your fingers to reconnect the wire.
  10. HTC Rhyme charging port Replacement: step 10, image 1 of 3 HTC Rhyme charging port Replacement: step 10, image 2 of 3 HTC Rhyme charging port Replacement: step 10, image 3 of 3
    • Disconnect the white cord on the lower left side of the motherboard.
  11. HTC Rhyme charging port Replacement: step 11, image 1 of 3 HTC Rhyme charging port Replacement: step 11, image 2 of 3 HTC Rhyme charging port Replacement: step 11, image 3 of 3
    • Gently remove the motherboard with your hand.
  12. HTC Rhyme charging port Replacement: step 12, image 1 of 3 HTC Rhyme charging port Replacement: step 12, image 2 of 3 HTC Rhyme charging port Replacement: step 12, image 3 of 3
    • Desolder and remove the charging port on the motherboard.
    • Solder a new charging port onto the pads where the previous charging port had been.
  13. HTC Rhyme charging port Replacement: step 13, image 1 of 3 HTC Rhyme charging port Replacement: step 13, image 2 of 3 HTC Rhyme charging port Replacement: step 13, image 3 of 3
    • Follow steps 11 through 1, to put the phone back together.
Rebecca Chapman
104 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 291
