HTC Sensation / 4G / Pyramid - Touch Screen / Digitizer Replacement
Video Overview
  1. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: step 1, image 1 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: step 1, image 2 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement, Touch Screen / Digitizer: step 1, image 3 of 3
    • Unscrew 8x screws and remove the back cover using a plastic tool.
  2. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 2, image 1 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 2, image 2 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 2, image 3 of 3
    • Disconnect the LCD display cable and the menu buttons cable.
    • There are another two cable connector between the main board and the additional upper board.
  3. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 3, image 1 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 3, image 2 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 3, image 3 of 3
    • In case to remove the upper board, unscrew the screw and release the power button flex cable and the volume up/down flex cable.
    • In another side of the board is the touchscreen flex cable connector.
  4. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 4, image 1 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 4, image 2 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 4, image 3 of 3
    • Use hot air to warm the touchscreen.
    • With a plastic tool start to separate the touchscreen.
    • Gently release the menu flex cable from the touch screen.
  5. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 5, image 1 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 5, image 2 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 5, image 3 of 3
    • The touchscreen flex cable go between the LCD display and the upper case / housing.
    • Again use a plastic tool and hot air to free up the cable.
    • Work carefully to avoid breaking the display.
  6. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 6, image 1 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 6, image 2 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 6, image 3 of 3
    • I use toothpicks and hot air to make place for the cable of the new spare part.
  7. HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 7, image 1 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 7, image 2 of 3 HTC Sensation / 4G / Pyramid -  Touch Screen / Digitizer Replacement: step 7, image 3 of 3
6 other people completed this guide.
ZFix
191,882 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 4,106
