HTC Thunderbolt MicroSD Card Replacement
  1. HTC Thunderbolt MicroSD Card Replacement, Rear Panel: step 1, image 1 of 1
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt MicroSD Card Replacement: step 2, image 1 of 1
    • Lift and remove the rear panel.
  3. HTC Thunderbolt MicroSD Card Replacement, Battery: step 3, image 1 of 2 HTC Thunderbolt MicroSD Card Replacement, Battery: step 3, image 2 of 2
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: step 4, image 1 of 2 HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: step 4, image 2 of 2
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt MicroSD Card Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
Vanessa
60 Reputation
4 Guides authored
Cal Poly, Team 19-45, Regan Winter 2013 Member of Cal Poly, Team 19-45, Regan Winter 2013
CPSU-REGAN-W13S19G45
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,565
