HTC Touch Camera Lens Replacement
  1. HTC Touch Camera Lens Replacement, Camera Lens: step 1, image 1 of 1
    • Remove the back panel by sliding it up.
  2. HTC Touch Camera Lens Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. HTC Touch Camera Lens Replacement: step 3, image 1 of 1
    • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
  4. HTC Touch Camera Lens Replacement: step 4, image 1 of 2 HTC Touch Camera Lens Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to remove the front panel from the phone.
    • Unplug the front button cable from the inside of the phone.
  5. HTC Touch Camera Lens Replacement: step 5, image 1 of 1
    • Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
  6. HTC Touch Camera Lens Replacement: step 6, image 1 of 2 HTC Touch Camera Lens Replacement: step 6, image 2 of 2
    • Seperate the motherboard from the black plastic casing.
    • Unplug the black and red wire from the motherboard.
    • Unplug the black and red wire from the black plastic casing.
  7. HTC Touch Camera Lens Replacement: step 7, image 1 of 1
    • Lift the black lever next to the orange ribbon cable to remove the LCD Screen.
  8. HTC Touch Camera Lens Replacement: step 8, image 1 of 1
    • Remove the camera lens from the motherboard using the plastic opening tool.
Sehyun
57 Reputation
1 Guide authored
Cal Poly, Team 15-12, Regan Spring 2011 Member of Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 2,663
