HTC Touch Front Buttons Replacement
  1. HTC Touch Front Buttons Replacement, Front Buttons: step 1, image 1 of 1
    • Using your finger, remove the back panel by sliding it up.
  2. HTC Touch Front Buttons Replacement: step 2, image 1 of 1
    • Remove the battery.
  3. HTC Touch Front Buttons Replacement: step 3, image 1 of 1
    • Remove the four screws in the corners of the phone using the T5 Torx screwdriver.
  4. HTC Touch Front Buttons Replacement: step 4, image 1 of 2 HTC Touch Front Buttons Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to remove the front panel from the phone.
    • Unplug the front button cable from the inside of the phone.
  5. HTC Touch Front Buttons Replacement: step 5, image 1 of 1
    • Remove the two screws from the back of the front panel using the Phillips #00 screwdriver.
  6. HTC Touch Front Buttons Replacement: step 6, image 1 of 1
    • Remove the small circuit board by gently pushing on the center button on the front of the phone.
  7. HTC Touch Front Buttons Replacement: step 7, image 1 of 1
    • Remove the buttons by pushing on them from the front side of the phone.
Andrew Brooks
104 Reputation
2 Guides authored
Cal Poly, Team 15-12, Regan Spring 2011 Member of Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Members
10 Guides authored
1 Guide Comment
I need the keypad flex cable. Where to buy. Please guide smahapatra2012@gmail.com
subhas mahapatra - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 3,042
