HTC Touch Pro 2 Camera Replacement
  1. HTC Touch Pro 2 Camera Replacement, Battery: step 1, image 1 of 3 HTC Touch Pro 2 Camera Replacement, Battery: step 1, image 2 of 3 HTC Touch Pro 2 Camera Replacement, Battery: step 1, image 3 of 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Camera Replacement: step 2, image 1 of 2 HTC Touch Pro 2 Camera Replacement: step 2, image 2 of 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners.
  3. HTC Touch Pro 2 Camera Replacement, Camera: step 3, image 1 of 2 HTC Touch Pro 2 Camera Replacement, Camera: step 3, image 2 of 2
    • Remove the four screws from the corners of the phone using a T5 Torx screwdriver.
  4. HTC Touch Pro 2 Camera Replacement: step 4, image 1 of 3 HTC Touch Pro 2 Camera Replacement: step 4, image 2 of 3 HTC Touch Pro 2 Camera Replacement: step 4, image 3 of 3
    • Lift the top segment of the phone frame off.
    • Be cautious with the ribbon on the back of this part.
  5. HTC Touch Pro 2 Camera Replacement: step 5, image 1 of 2 HTC Touch Pro 2 Camera Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to pull the camera cover up and away from the phone. Repeat for the camera underneath.
Melinda Phan
438 Reputation
9 Guides authored
Cal Poly, Team 9-64, Walters Spring 2011 Member of Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 2,613
