HTC Touch Pro 2 Housing Replacement
  1. HTC Touch Pro 2 Housing Replacement, Battery: step 1, image 1 of 3 HTC Touch Pro 2 Housing Replacement, Battery: step 1, image 2 of 3 HTC Touch Pro 2 Housing Replacement, Battery: step 1, image 3 of 3
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Housing Replacement: step 2, image 1 of 2 HTC Touch Pro 2 Housing Replacement: step 2, image 2 of 2
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners.
  3. HTC Touch Pro 2 Housing Replacement, Housing: step 3, image 1 of 2 HTC Touch Pro 2 Housing Replacement, Housing: step 3, image 2 of 2
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • Potential for device damage: There is a ribbon attached on the back of this part that requires caution to remove.
  4. HTC Touch Pro 2 Housing Replacement: step 4, image 1 of 3 HTC Touch Pro 2 Housing Replacement: step 4, image 2 of 3 HTC Touch Pro 2 Housing Replacement: step 4, image 3 of 3
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
2 other people completed this guide.
Melinda Phan
438 Reputation
9 Guides authored
Cal Poly, Team 9-64, Walters Spring 2011 Member of Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 31
All Time: 4,115
