HTC Trophy Motherboard Replacement
  1. HTC Trophy Motherboard Replacement, Battery: step 1, image 1 of 3 HTC Trophy Motherboard Replacement, Battery: step 1, image 2 of 3 HTC Trophy Motherboard Replacement, Battery: step 1, image 3 of 3
    • Power off the phone before starting.
    • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
  2. HTC Trophy Motherboard Replacement: step 2, image 1 of 3 HTC Trophy Motherboard Replacement: step 2, image 2 of 3 HTC Trophy Motherboard Replacement: step 2, image 3 of 3
    • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
    • Apply a small force towards the bottom of the phone and lift upwards.
    • Be careful not to puncture the battery.
  3. HTC Trophy Motherboard Replacement, Display Assembly: step 3, image 1 of 3 HTC Trophy Motherboard Replacement, Display Assembly: step 3, image 2 of 3 HTC Trophy Motherboard Replacement, Display Assembly: step 3, image 3 of 3
    • Remove the 5 screws holding the two phone halves together.
    • Three 4mm long T5 Torx screws.
    • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
    • One 4mm long Philips #000 screw.
    • Remove the installed SIM card if one is present.
  4. HTC Trophy Motherboard Replacement: step 4, image 1 of 3 HTC Trophy Motherboard Replacement: step 4, image 2 of 3 HTC Trophy Motherboard Replacement: step 4, image 3 of 3
    • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
    • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
    • The volume button will fall out when the phone is opened.
    • The black sticker beneath the battery will rip once the phone is separated.
  5. HTC Trophy Motherboard Replacement: step 5, image 1 of 3 HTC Trophy Motherboard Replacement: step 5, image 2 of 3 HTC Trophy Motherboard Replacement: step 5, image 3 of 3
    • Remove the three screws holding the mother board to the display assembly.
    • One 2mm long Philips #000 screw.
    • Two 4mm long T5 Torx screws in the holes of the plastic.
  6. HTC Trophy Motherboard Replacement: step 6, image 1 of 3 HTC Trophy Motherboard Replacement: step 6, image 2 of 3 HTC Trophy Motherboard Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the black tape cover the ribbon cable connectors with tweezers.
    • Disconnect the ribbon cables from the connectors.
    • Ribbon cables are extremely fragile.
  7. HTC Trophy Motherboard Replacement: step 7, image 1 of 2 HTC Trophy Motherboard Replacement: step 7, image 2 of 2
    • Remove power button from the top of the phone with tweezers.
  8. HTC Trophy Motherboard Replacement: step 8, image 1 of 3 HTC Trophy Motherboard Replacement: step 8, image 2 of 3 HTC Trophy Motherboard Replacement: step 8, image 3 of 3
    • Use the iFixit opening tool to separate the motherboard from the display assembly.
  9. HTC Trophy Motherboard Replacement, Motherboard: step 9, image 1 of 3 HTC Trophy Motherboard Replacement, Motherboard: step 9, image 2 of 3 HTC Trophy Motherboard Replacement, Motherboard: step 9, image 3 of 3
    • Remove the plastic piece off of the motherboard.
    • Put pressure outwards to release these clips with the iFixit opening tool and you fingers.
Always dispose of e-waste properly. Follow this guide on how to dispose of the old motherboard.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 332
