HTC Vive Cosmos Disassembly
  1. HTC Vive Cosmos Disassembly, Remove Faceplate: step 1, image 1 of 1
    • pull from the nose and top middle to remove the face plate
  2. HTC Vive Cosmos Disassembly, Remove Frontplate: step 2, image 1 of 1
    • Hold the button on the inside of the headset.
    • Pull back the frontplate away from the Vive.
  3. HTC Vive Cosmos Disassembly, Remove Warranty Stickers: step 3, image 1 of 1
    • Peel the two warranty stickers using a driver.
    • Covers may be peeled back using other tools like a spudger.
  4. HTC Vive Cosmos Disassembly, Remove Camera Plate Screws: step 4, image 1 of 1
    • Unscrew nineteen screws using the T5 Torx driver.
  5. HTC Vive Cosmos Disassembly, Remove Covers: step 5, image 1 of 2 HTC Vive Cosmos Disassembly, Remove Covers: step 5, image 2 of 2
    • Remove the covers beneath the warranty stickers.
  6. HTC Vive Cosmos Disassembly, Remove Plate: step 6, image 1 of 1
    • Insert card between plate and camera plate to separate and remove.
    • May use card or other soft flat surfaces like a spudger.
  7. HTC Vive Cosmos Disassembly, Detach Headband: step 7, image 1 of 1
    • Unscrew the three torx screws using the T5 X 50 mm screwdriver.
    • Unscrew the one Philips screw using the 10 mm screwdriver.
    • Detach headband from headset.
  8. HTC Vive Cosmos Disassembly, Remove Camera Plate: step 8, image 1 of 1
    • Insert card between camera plate and the headset to separate.
  9. HTC Vive Cosmos Disassembly, Remove Focus Knob: step 9, image 1 of 1
    • Slide the focus knob out of the plastic holding and off the focus rod.
  10. HTC Vive Cosmos Disassembly, Unplug Jumper Cables: step 10, image 1 of 2 HTC Vive Cosmos Disassembly, Unplug Jumper Cables: step 10, image 2 of 2
    • Static Warning for circuit board interaction. When dealing with jumper cables and circuit boards touch metal not located on Vive for 15 seconds before removing component. Keep in mind for remaining steps.
    • Unplug the jumper cables from the circuit boards to detach.
  11. HTC Vive Cosmos Disassembly, Detach Jumper Cables: step 11, image 1 of 1
    • Unscrew the four silver Torx screws on the jumper cables using the T5 driver.
    • Keep note of the four silver Torx screws which are different than the other screws.
    • Pull the jumper cables away from the holding and remove.
  12. HTC Vive Cosmos Disassembly, Remove Cable Port Board Screws: step 12, image 1 of 1
    • Unscrew the five black Torx screws using the T5 driver on the circuit board.[two more off the left of the image]
  13. HTC Vive Cosmos Disassembly, Remove Strip Plugs: step 13, image 1 of 1
    • Remove the jumper cables to fully release the cable port board.
  14. HTC Vive Cosmos Disassembly, Unscrewing Camera Board: step 14, image 1 of 1
    • Unscrew the six Torx Screws on the camera board with the T5 driver.
  15. HTC Vive Cosmos Disassembly, Remove Fan Screws: step 15, image 1 of 1
    • Unscrew the one Torx Screw using the T5 driver.
  16. HTC Vive Cosmos Disassembly, Remove Heat Duct: step 16, image 1 of 1
    • Pull and maneuver the heat duct out of the holding.
    • Exercise caution to carefully remove component.
    • The thermal paste may scratch off in the process but that is okay.
  17. HTC Vive Cosmos Disassembly, Unplug Fan: step 17, image 1 of 2 HTC Vive Cosmos Disassembly, Unplug Fan: step 17, image 2 of 2
    • Unplug the fan from the camera board.
  18. HTC Vive Cosmos Disassembly, Remove Additional Strip Plugs: step 18, image 1 of 1
    • Insert screwdriver beneath strip plug to remove.
    • May use another tool that is able to fit beneath strip plug and gently remove.
  19. HTC Vive Cosmos Disassembly, Remove Camera Board: step 19, image 1 of 1
    • Lift camera board and remove.
Jalyssa Smith
289 Reputation
1 Guide authored
1 Guide Comment
Thanks for not mentioning the microphone and the fact that you also tore yours doing the disassembly! Will you replace the mic that was working before i took it apart to repair other issues? No? Exactly. Don't do any more guides and people: find a better one. Moron.
Lee Ball - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 52
All Time: 1,421
